question on WinALDL
Car: 91 Red Sled
No. It should be going on/off. DRP occured is the same as the 1228746's "reference pulse occured". It's basically saying that the engine is rotating, nothing more. It happens VERY fast so don't expect there to be some kind of pattern to it's on/off state. Obviously the higher the RPM the more frequent a DRP occures but with 160baud good luck catching it.
