fuel injector change question
Old Oct 26, 2005 | 07:45 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
if the only change in one of my chips over stock was to change the constant for FI size from 22 to 24, and the car was to feel slower, where would i first check into the issue?
Old Oct 26, 2005 | 10:03 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
You have to look at the parameter you are changing with an expected output change.
If you upped the injector size in the bin it will cause one thing to happen for sure.
The pulse width will be less for a given calculated output
(bigger injector does not need to be opened as long as a smaller one to get the same amount of fuel)
You should have seen the PW drop slightly for the same load point. With that being said your BLM will have changed because the amount of fuel for the same load point has changed. The calculations in closed loop will correct for the difference and you'll be able to see something that correctly responds to your change.
Whenever you make a change you should have a fairly good idea what to expect from it or you are shooting in the dark. It easy to go in circles like that.
Plan your changes and look for the result, if the result does not appear correct then go back and rethink your strategy. It might turn out that you are changing the wrong parameter to solve a problem.
HTH
Old Oct 26, 2005 | 10:11 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
im not trying to solve a problem, i really have 24# injectors, and i just wanted to correct that in the ecm accordingly.
Old Oct 26, 2005 | 10:27 PM
JP86SS's Avatar
Thats good to get things where they belong
Do some logging and begin working in the VE tables (or whatever they are called for you MAF) I'm mainly an SD guy so I'm not much help with MAF tuning. Go back to your baseline spark tables, You should see the problem with fueling quickly with some logging. Work the BLMs into shape then play with spark.
Back to the stickies and tuning guide for you
You'll just have to keep driving around and tuning until you get it feeling better at this point.
JP86SS's Avatar
Are you getting knock counts with the gear drive?
That could be a big part of your problem.
Old Oct 26, 2005 | 10:30 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i dont have access to datalogging til this weekend so i dunno, i doubt it though, lots of people here have admitted running a quite drive for quite a bit of time without any knock.
bryan623
Mar 22, 2021 06:43 PM
jklein337
Sep 19, 2018 06:23 PM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
