Some $58 fun....
Old Nov 6, 2005 | 08:37 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Some $58 fun....
Looks like the BPC vs EGR just uses the first data bit for non-EGR usage?
In that case, I'm computing BPC of 55.49 for a 3.1L running 36# injectors... sound right?
Also, the $58 is a 16k bin? Do I need to burn it at any offset?
Converting the harness and going to load up the '749 code on the '730 ecm running an SU129 tomorrow, thought I'd bounce a couple things off the brains in here
Also, since the prom IS an original 3.1L ('91) prom, the knock code should be correct on it, yes? I'll be throwing a code for that, but I would like to wire up a knock sensor for this little guy...
Old Nov 7, 2005 | 08:07 AM
Doward's Avatar
Anyone?
This is the formula I used -
BPW Constant = 1461.5 x (cyl vol / inj flow rate )
Cyl vol = vol of 1 cyl in L
inj flow rate = flow rate of the injectors in grams/sec
I would also like to know if there is any way to shut off the knock sensor in the code (or at least disable it temporarily, until I can wire one up)
Old Nov 7, 2005 | 10:28 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I just installed the $58 code yesterday and used this formula for BPC:
BPW vs EGR
The correct formula is: BPC = 730.75 * (vol of 1 cyl / inj flow in gms per sec)
BPC = 730.75 * (VOL / RATE)
; VOL = Vol of 1 Cylinder in liters
; RATE = Injector flow in gms/sec
; gms/sec = (lbs/hr / 3600) * 453.6
Old Nov 7, 2005 | 10:45 AM
Doward's Avatar
So ~83.24? I'll start with that, and see what goes on....
Btw, this is a 6 cyl MPFI application
Project 3.4 Camaro
May 7, 2012 04:55 PM
MadCelt
South East Region
45
May 1, 2012 07:02 AM
lhuser
Aug 23, 2011 09:36 PM
red30011
Oct 16, 2009 10:55 PM
