calc bpw (don't use table)
Old Nov 7, 2005 | 02:04 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
should this be checked or not whats teh difference the arap bin is checked my stock apyn bin is not.
Old Nov 7, 2005 | 12:16 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Just a WAG but Id guess tahts the option to use the PW vs. LV8 table. Id stick with the MAF calcs. Its better to use teh airflow directly rather then try to estimate the load and base the fueling off of that.
Old Nov 7, 2005 | 12:20 PM
Car: 88 Camaro SC
Engine: SFI'd 350
As for the difference, the PW vs. LV8 vs. RPM uses teh load variable to look up the actual pulsewidth needed for the injectors. The maf calcs uses the airflow to calculate the needed injector duty cycle, which is then multiplied by the DRP to get the pulsewidth. Again, this is assuming that Im not mistaken and thats what the table is in your bin.
Azrael91966669
25
Jun 20, 2017 04:04 AM
fasteddi
Sep 2, 2015 10:29 AM
htrdbmr
Aug 18, 2015 12:58 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
