OBD 1 DIY cable
Old Nov 8, 2005 | 12:14 AM
Art_H's Avatar
OBD 1 DIY cable
Just a quick couple of questions:
1. I have been investigating the various DIY OBD ALDL-RS232 cables. I have found 2 types. 1 basic with a few resistors and transistors, and the 2nd has a more complex IC setup, presumably for the OBD 2 4th gen types.
Ques:
1. Which of the cables is required for data logging etc. on the OBD 1 system, and which baud rate is reqiured?
2. What baud does the 7165 use?
3. Do all TBI use 160 baud?
Thanks, Art
*Rest assured that I have made great use of the "Search" feature already.
Old Nov 8, 2005 | 09:14 AM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
1) It depends. There's a 1-transistor cable that works for 160-baud. There's a 2-transistor cable that works for 160 and 8192 baud. There's the MAX232/233 that works for everything as well. The one with the series diodes on the data line is good for the reflash of the 94/95 LT1 also.
2) The 165 uses both. It starts in 160 baud mode, and then when you send it a properly timed request, it switches to 8192 mode.
3) No. Later model TBI (93+ stuff with the 27C512 memcal) use 8192. But most of the 3rd gen stuff TBI is 160, yes.
Old Nov 8, 2005 | 06:40 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
So the 2 transistor cable will read both 160 and 8192 baud?
Sweet
Old Nov 8, 2005 | 10:37 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Is this why Diacom would not read in anything other than special mode (IE. 10K across A-B)? I recall never being able to get anything more than the 160 mode and it would always idle at 1000RPM.
Mark.
Old Nov 8, 2005 | 11:40 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I prefer the MAX232/233 cables. In datamaster I have not been able to get a 2 transistor cable to read up to the full 10 records a second where my MAX232/233 cable holds steady at 10 records a second. I could just as easily be doing something wrong though.
Old Nov 10, 2005 | 02:02 AM
Art_H's Avatar
Thanks for the info.
Due to the simple ease of the 2 trans cable I think I'll try that for now.
What clock speed does the early TBI operate on?
Is the only problem with this setup then is the low comm rate for data logging etc. ?
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
