Who knows as to replace 727 on 749 ?(TT-vette'91) help!
Old Nov 9, 2005 | 08:23 AM
Dmitri's Avatar
Car: corvette 87
Engine: 383
Transmission: 4L60
???? help!
Old Nov 9, 2005 | 12:17 PM
Z69's Avatar
Z69
You can simply swap to the $58 code and use it for boost.
No ecm swap necessary unless you want more than 800 or so HP.
See the $58 Frequently asked Questions thread up at the top of the board in the stickies. Same thread as the 165 stuff I already sent you too.
Old Nov 9, 2005 | 09:11 PM
Dmitri's Avatar
Car: corvette 87
Engine: 383
Transmission: 4L60
replace PROM $8D on PROM $58 ????
To replace PROM $8D on PROM $ 58 - I correctly has understood?
And it is necessary to replace 1-bar MAP on 2-bar MAP?
Write the answer please
Old Nov 9, 2005 | 09:36 PM
Dmitri's Avatar
Car: corvette 87
Engine: 383
Transmission: 4L60
Should I do repining, how in a case with 730 to 749 ???
Old Nov 9, 2005 | 11:38 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Yes you need a 2 bar map
Se this thread
https://www.thirdgen.org/techbb2/sho...hreadid=329903
and do a search for "$58" and "boost" and "749" and you will find alot of info..
good luck!
/N.
Old Nov 10, 2005 | 05:37 AM
Z69's Avatar
Z69
Dig around here http://www.cruzers.com/~ludis/ to find a pin list for a 727/730 and just use the 730 to 749 pin swap list. But use the 727 pinout instead.
Not very many wires need moved to allow running a $58 bin on a 730. Once you research it a little, you'll see the wiring is the easy part.
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
