Data Logging with TunerPro
Old Nov 12, 2005 | 07:09 PM
BadDog's Avatar
Well, I have reached my max frustration rate for one day...
It seems I have a successful chip burn with akaj1147.bin and the 747.ecu.
It seems that I can emulate using TunerPro RT and AutoProm. At least it runs just as well as it does with the chip, so I guess emulation is working.
I finally did get it to log in stand alone (hardware) mode, but I can't get the blasted thing to log while emulating. I've tried everything I can find in the Moats documents, and I've gone through the TP-RT docs. And I've read quite a bit in searching here. All with no luck.
It says it's connecting. Sometimes I get garbage for "Actual Sample Rate" and "Error counts" climbing rapidly. But in the "integrated" mode (vertical switch in center, horiz toward the center) I have managed to get no errors and "actual" rate of sometime 0, sometimes 0.6. But even when it says it's connected, and when errors are not shown anywhere, the Dashboard and other data is all "0".
I'll look into it more tomorrow when the frustration level is lower. If this rings any bells, I would appreciate any pointers you have. It's probably something simple I'm overlooking…
Old Nov 13, 2005 | 09:38 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Craig's fixing the AutoProm firmware to work for 160 baud monitoring in non-passthrough (autoprom) mode. I'll notify you when this is working (should be in the next few days).
M
Falcon50
Aug 22, 2020 03:26 PM
Mark_ZZ3
May 24, 2018 01:02 PM
bjpotter
Oct 4, 2015 07:48 PM
ULTM8Z
Oct 2, 2015 01:25 PM
BWilcox
Sep 20, 2015 12:19 PM
