OL AFR vs Coolant Temp
Old Nov 12, 2005 | 07:37 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
What is this table used for?
Also, Open Loop AFR vs Vac?
To lower IAC counts, would it be beneficial to lower settings in IAC Motor Reset Postion vs Barometer?
$85 16147060
OK, I think I found most of it. The first 2 apply at idle only, correct?
Old Nov 12, 2005 | 07:54 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The AFR vs. coolant gives more fuel to the engine when it is still cold or starts to overheat. You can dial in the basic air/fuel mixture here. The AFR vs. Vac, changes the air fuel ratio with engine vacuum. Generally the higher the vacuum the less fuel the engine needs. These tables are added togather and used for fuel calculations when in open loop. It is also used in closed loop calculations, just the O2 sensor is correcting the mixture to 14.7:1.
Changing the IAC position at reset is benificial if you have a RPM flare at start-up.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
