Mosi/miso
Old Dec 1, 2005 | 09:14 AM
Z69's Avatar
Z69
Mosi/miso
I know what it stands for but not what it does.
Any help????
Is this how the SPI data is routed?
Or is that done some other way?
A ref to how this works would be fine.
Old Dec 1, 2005 | 09:44 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Yes, SPI and MOSI/MISO are interchange kind of things. It is basically just a clock and data signals. A simple three wire serial bus. The ALDL is a two wire serial bus that uses two different clocks. The SPI uses the same clock.
You load data into an "SPI data reg" and then set a bit in the "SPI send cmd/data reg". The ECM MCU then sends out the data to the selected device which is usually the A/Ds or the discrete I/O device. The discrete I/O is used as a chip select for other devices.
The best ref I know of is the 68HC11 datasheet from Motorola. The SPI regs listed in the standard 68HC11 differ from the ECM MCU register set....different bit positions and addresses.
Old Dec 1, 2005 | 11:19 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
That is exactly what has been making this so difficult to determine all of the sequences needed to run the I/O.
Still working on it.
1 bit of good news, I was just handed a full Motorola development kit that a coworker bought some years back.
Between that and my simulation program I'm hoping I can get these worked out on the std unit and then figure how the ECM is doing it.
I know they are relocated to $4000-$400F.
The "K" series was the only one that supported PWM outputs, the ECM is more closely resembling an "F" series from what I've read. The routines are vastly different because of opcodes that were used in the "K"s. The K has control words in the $0060 range as well.
Old Dec 1, 2005 | 12:45 PM
Z69's Avatar
Z69
Thanks J,
Is the CS line the 3rd wire and data goes on it?
Or is it simply a select this chip?
Is the data sheet not in the pink book?
The bits being moved is what threw me.
I could handle the re address.
Finally just looked at every read/write in the 8D till it hit on a few cylinders.
Nothing like drawing a map to a place you've never been.....
Using a foreign language.
Old Dec 1, 2005 | 01:21 PM
AlexJH's Avatar
Engine: 5.7L V8
Originally posted by Z69
Thanks J,
SPI always uses 4 lines:
CS means chip select (sometimes it's negative logic ie set to 0 to select, 1 to deselect). You can have a whole bunch of chip selects going to different chips.
MOSI - Master Out Slave In
MISO - Yummy Japanese soup
Clock - for the timings
MOSI is the output, MISO is the input. When a transfer is run, it always goes both ways even though there might not be any data to send in a certain direction.
Here are some good links:
http://www.totalphase.com/support/articles/article03/
http://cnx.****.edu/content/m11993/latest/
http://www.atmel.com/dyn/resources/p...ts/doc2582.pdf
I tried to find you an example diagram that shows what the lines do during the transfer, but I didn't have any luck.
Old Dec 1, 2005 | 01:33 PM
junkcltr's Avatar
Engine: 3xx ci tubo
No, the CS is not the third wire. The three wires are:
SCK = serial clock
SDI = serial data in
SDO = serial data out.
In the $58 code I am commenting I have a few places where it talks about the SPI stuff and what is going on like A/D reads, optical VSS setup, etc. Basically, you write a value at 0x4002 which does a chip select by controlling the MCU pins (this has nothing to do with the SPI). Then you fill the SPI reg 0x4000 with the data destined for the chip you just chip selected. Then you set the "send SPI data" bit (bit_7 referenced to zero) at 0x4001. The data is then sent to the SPI port and at the same time data is recieved in register 0x4000. Keep that in mind, when you transmit SPI data, you also receive SPI data at the same time.
I might be able to show this more clearly with a snapshot of some of the commented $58 code doing this with pin numbers, device numbers, register numbers, etc. A complete example is usually easier to follow.
Yeah, the non-standard reg/memory map is confusing. I had always planned on exploring it further....just never got around to it yet. I do not have a pink book and have never read one. I use the datasheet from Motorola I downloaded years ago. Something called 68HC11collateral.pdf or something like that. I also downloaded the instruction set pdf that gives the instruction CPU cycles & flag settings from the Motorola site. The Motorola docs are very good.
J
Old Dec 1, 2005 | 01:51 PM
Z69's Avatar
Z69
Thanks,
Now I need to go figure out how $4003 is used.
And the whole 3FFC reg still has us a little confused.
Some of it's obvious. Some isn't.
With the re-enforement you guys gave I'll see if more of it makes sense now.
Old Dec 1, 2005 | 02:11 PM
junkcltr's Avatar
Engine: 3xx ci tubo
If you look at page 1 of Ludis' 730 schematic, you will see that the MCU has a bunch of pins on the left side. The way I see it is that the direction of the pins is set via reg 0x4003. The $8D code sets them all to '1' (all outputs). When you write to reg 0x4002, then that sets the value of each pin either high (1) or low (0).
The 0x3FFC is a parallel bus thing (not SPI). Look at page one again and over on the right is chip U2. It has PWM3FCC, etc. stuff on it. The SES light is located at address 0x3FFC, bit_1.
I haven't played with that stuff on the bench. I need to write a couple of little test code pieces to see which bit does what.
Old Dec 1, 2005 | 07:29 PM
JP86SS's Avatar
From what I see in $8D,
3FFC b1 = SES ? (referenced somewhere I found)
3FFC b2 = A/C Clutch
3FFC b3 = SES LIGHT "E7" pin This is where the light IS wired to.
3FFC b4 = ???
3FFC b5 = Alternating Fuel ?
(maybe this is the "Out3 or 4" that switches the PWM 7 into action on Q2)
don't find anything on the rest of that word except that the "init" sends a double word there. So 3FFC and 3FFD are being setup.
; Init CPU 0xFB12 = 1111 1011 0001 0010 (b3 OFF is change from the previous loading of the initialization value)
I believe that is the "blink" on the SES when you first power up the ecm.
Loading $FF into $4003 sets the direction of $4002 to output.
Old Dec 2, 2005 | 12:42 AM
junkcltr's Avatar
Engine: 3xx ci tubo
A little example from the BBZB:
Code:
LC849: 	DEX			; decrement reg_x (reg_x--)
 	CPX  	#0x100		; compare reg_x with RAM address 0x0100 (F.T. mode word)
 	BEQ  	LC849		; branch if at the F.T mode word (don't clear it)
 	CPX  	#30             ; compare reg_x with 0x001E
 	BNE  	LC847		; branch if not at the beginning of RAM
 	CLRA			; reg_a = 0 (it is already cleared)
	;; Check if Magnetic Vehicle Speed Sensor (VSS) is installed
	;; if installed, then don't disable SXR
	;; Check PROM word 0xC334 for Mag. VSS
 	LDAB 	LC334		; Flag WD 0010  1101b
 	BITB 	#0x40            ; check if bit_6 is set (magnetic VSS)
 	BNE  	LC85E		; branch if not zero, bit_6 is set (magnetic installed)
 	LDAA 	#0x10		; reg_a = 0x10 (disable SXR bit) VSS follows VSS1
	;; Bit_4 of the SPI word to the U10 digital I/O device DOES NOT go to an output pin
	;; It is a control bit for the device internally
	;; Bit_8 of the SPI word to the U10 digital I/O device disables the SXR/ALDL chip
LC85E: 	ORAA 	LC0F2		; reg_a ORed with the road speed divisor
	;; The road speed pulse divisor is sent to chip U24 to divide down the VSS signal
	;; The 0x58 default road speed divisor is 0
	;; The divisor consists of three signals:  DIVA, DIVB, and DIVC
	;;   which are all controlled by U10 (digital I/O device)
	;; reg_a contains the digital settings for the 3 DIVx signals and
	;; The RELAY# and F6OUT are NOT used by the 0x58 Syclone (ECM pins unused)
 	STAA 	*L00C2		; MEM[0x00C2] = reg_a
	;; 0x00C2 contains the word that is sent to the Digital I/O chip U10
 	JSR  	LF4B9		; call 0xF4B9 (SPI bus TX routine)
	;; The 0xF4B9 routine asserts GLUCS_L to device U10 and uses SPI to TX data
	;; Initialize the FMD_2 device (FMD_1 was initialized early on)
 	LDX  	#0x4002		; reg_x = 0x4002 (GPIO reg)
 	BSET 	0,X,#0x40	; set bit_6 of MEM[0x4002] (III2CS = 1, select FMD_2 device)
 	LDAA 	#4		; reg_a = 0x04
 	JSR  	LFF37		; send reg_a to FMD_1 device via SPI bus
 	BCLR 	0,X,#0x40        ; clear bit_6 of MEM[0x4002] (III2CS = 0, de-select FMD_2 device)
	;; * Address LFAD3:	Init code
	;; * Inputs:	 NONE
	;; * Outputs:	 TBD
	;; * performed at startup & reset
	;; * Setup the SCI I/F, GPIO pins, checksum calc,
	;; * check for 3.9K resistor on ALDL (F.T. mode request)
	;; * and do F.T. mode if requested
LFAD3: 	LDAA 	#140		; reg_A = 1000_1100 (0x8C)
				; This sets up the SCI I/F
 	STAA 	L4001		; MEM[0x4001_SCIreg] = 0x8C
 	LDAA 	#136		; reg_A = 1000_1000 (0x88)
				; This sets up the GPIO pins
 	STAA 	L4002		; MEM[0x4002_GPIOreg] = 0x88
				; assert ADCCS_L, GLUCS_L high
	;; Writing MEM[0x4002] = 0x88 disables all chip selects to
	;; all of the external devices.
 	LDAA 	#255		; reg_A = 1111_1111 (0xFF)
				; This sets up the GPIO data direction
				; for register 0x4002 (1 = output)
 	STAA 	L4003		; MEM[0x4003_GPIODDR] = 0xFF
	;; * All pins controlled by register 0x4002 GPIO are now OUTPUTS
 	LDAA 	#144		; reg_A = 1001_0000 (0x90)
				; setup SCI ALDL I/F for 8192 Hz baud rate
 	STAA 	L4004		; MEM[0x4003_SCIMUX] = 0xFF
	;; * end of setting up hardware GPIO and SCI ALDL I/F
 	LDX  	#0x3FC0		; X = 0x3FCO (time between distr. pulses)
				; also called the ref. period between DRP
				; distributor reference pulses in millisec.
 	CLRA			; D_reg = 0
 	CLRB
	;; Clear CPU RAM from 0x3FC0 - 0x3FFA
	;; for(reg_x = 0x3FC0; reg_x < 0x3FFA; reg_x++)
	;;  reg_x = 0
LFAEC: 	STD  	0,X		; clear the time between DRPs
 	INX			; increment X reg
 	INX 			; increment X reg, again
 	CPX  	#0x3FFA		; at the end of RAM space??
 	BNE  	LFAEC		; branch if not at end (reg_x != 0x3FFA)
	;; Init. the CPU using CPU reg at 0x3FFC which is
	;; located in chip U2 (digital I/O chip)
	;; This appears to turn the check engine light off
 	LDD  	#0x000A		; else, reg_D = 0x000A
 	STD  	L3FFC		; MEM[0x3FFC] = reg_D
	;; 1) Calculate PROM 8 bit checksum (set error 51 is incorrect)
	;; 2) Initialize the Fuel Management DeviceFMD_1
	;; 3) Check if Fuel Pump voltage is greater than 16.0 volts,
	;;    Battery voltage is less than or equal to 10.0 volts,
	;;    and 3.9K ohm (3.4K to 6.3K) resistor on ALDL pin.
	;;    If all are true, then Factory Test (F.T.) mode is requested
	;;    and the F.T. code is jumped to.  Else, return to caller
 	LDX  	#0xC008		; start of PROM to calc checksum
 	JSR  	LFF1F		; call check sum routine
	;; checksum start address is sent in reg_x
	;; checksum result is returned in reg_y
 	LDX  	#0x0100		; New Err Address
 	CLR  	0,X		; MEM[0x0100] = 0x00
 	CPY  	LC006		; compare reg_y to MEM[0x4006]
	;; compare the calc_checksum to the const_table checksum
 	BEQ  	LFB0F		; BR if check_sums match
 	BSET 	0,X,#0x10	; else, Set b4  EPROM Err 51 in MEM[0x0110]
	;; 0x0100 = factory test mode word
	;; 0x0110 = PROM errors (err 51 set here)
	;; initialize FMD and setup other external hardware
	;; initialize fuel management device 1 (FMD 1)
LFB0F: 	LDAA 	#4		; reg_a = 0x04 (III1CS signal)
 	TAB			; reg_b = reg_a
 	STD  	L0113		; MEM[0x0113] = 0x0404
	;; 0x0113 = FMD_1 data buffer address
 	JSR  	LFEFA		; call 0xFEFA (init FMD_1 device fxn via SPI bus)
 	ANDA 	#0x03		; reg_a & 0x03, mask the SPI returned data
				; from the FMD_1 device, Fact. test mode bits
 	STAA 	L0110		; save the result to 0x0110
	;; now start checking the Analog to Digital converter values (A/D, ADC)
	;; chips U5 and U6, U5 is primary and U6 is secondary and is read via
	;; U5 channel AN9 (chan_9)
 	CLRA			; reg_a = 0, read channel_0 (MAP2 signal-pin F14)
	;; Pin F14 is unused by the 1992 4.3L turbo Syclone
	;; This is being done to initialize the called function so that
	;; the A/D test channel is read (Vref -> 2.5V nominal)
	;; Every time the A/D performs a request, it receives the previous A/D
	;; conversion that was done. It takes time to do the conversion.
 	JSR  	LFF53		; call 0xFF53 (A/D routine for channel_0)
 	LDAA 	#0x60		; reg_a = 0x60 (A/D channel 6 -> fuel pump)
 	JSR  	LFF53		; call 0xFF53 (A/D routine for channel_6)
 	CMPA 	#160		; compare fuel pump voltage with 160d
	;; fuel pump has a resistor divide input with Va2d = (8/(8+33)) Vpump
	;; In order for Va2d to be 5 Volts, then Vpump must be 25.625 volts
	;; Va2d = 8/41 * Vpump, Vread = (25.625/256) * Vcounts
	;; Vcompare voltage is:	(25.625/256) * 160 = 16.0 volts
 	BLS  	LFB38		; branch if less or equal to 16.0 volts (not F.T. mode)
	;; if Vpump greater than 16 volts, then Factory Test mode (F.T. mode) requested
 	LDAA 	#0x10		; reg_a = 0x10 (A/D channel 1 -> Battery voltage)
 	JSR  	LFF53		; call 0xFF53 (A/D routine for channel_1)
 	CMPA 	#100		; compare battery voltage with 100d
	;; Battery voltage input also has Va2d = (8/(8+33)) * Vbattery  resister divider
	;; Vcompare voltage is:	(25.625/256) * 100 = 10.0 volts
	;; if less than or equal to 10 volts, then Factory Test mode (F.T. mode) requested
	;; if Vbattery - 10 volts < 0, then F.T. mode requested (Vbatt less than 10.0 V)
 	BCC  	LFB38		; branch if greater than or equal to 10.0 volts (not F.T. mode)
 	JSR  	LFF12		; call 0xFF12 (Check for 3.9K ohm on ALDL pin)
	;; The carry bit is set upon return if Factory Test (F.T.) mode requested
 	BCS  	LFB39		; branch if carry bit is set (F.T. mode requested)
LFB38: 	RTS
