Help with ALDL cable
Old Dec 2, 2005 | 10:21 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
I just made a cable with the serial to usb converter. When i go to plug it in it doesnt transmit anything. I have an external 12v source. My laptop makes these noise when somthing gets unpluged. it keeps doing this till i unplug the ground?? Any ideas?
My car is a 89 camaro rs with a 305 tbi
Old May 22, 2006 | 03:22 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
TTT...I guess I need to get a cable that a serial to USB coverter since my new laptop only has USB ports...any info on this is good info for me.
Old May 22, 2006 | 05:28 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
If it makes the noise when unplugging/plugging the ALDL cable then you probably have it wired incorrectly. Things tend to make noise under high current changes. I would check the cable for a short to ground or power. Don't plug it in until you verified that you don't have an electrical short.
It is easy to mix up the wiring on the RS-232 connector side. Make sure you wired it properly at the DB9 (9 pin) connector.
Old May 22, 2006 | 09:27 AM
Home Built's Avatar
I had a problem with my aldl cable and usb adapter too..
Check the settings in your device manager for the usb adapter, make sure you don't have any conflicts and the drivers are installed for it. When I used mine it set it'self up on com 13. Changed it to com 2 and it worked great.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
