EEPROM For TBI
Old Dec 7, 2005 | 11:07 AM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
EEPROM For TBI
Is there such thing as a EEPROM for a TBI? Specificaly a 91. If so where can I get one?
Old Dec 7, 2005 | 11:10 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Gonna have to socket the ecm and use Craigs adapter to get there.
Than u just use 29c256 or the equivelant.
later
Jeremy
Old Dec 12, 2005 | 10:32 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Very well documented by Craig Moates
G2-Using a 29c256 EEPROM in a 2732a socket
What you need.
Product Description: Allows use of new Flash chips in many GM TBI setups. If the original application accepted a 24-pin chip such as a 2732A, then this adapter will allow you to upgrade to new Flash chips such as the AT29C256 and 27SF512. Soldering required (see product web page). This is the unit which will work if your original application had the chip holder with leg spacing of 0.45". Just check before ordering, you'll need to take the ECM apart to find out. Comes with everything you need to replace your stock chip holder with a standardized 28-pin chip socket that is compatible with the newer Flash chips. Installation service available for $25 if you're not comfortable soldering.What you need: Check Spacing first
As if 3.8 didnt give you a good enough expanation heres alittle more info with pics
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
