730/749 Rom
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
730/749 Rom
Has anyone ever dumped the rom routine code at $5000-$5FFF or $6000-$6FFF ?
Car: check
Engine: check
Transmission: check
Re: 730/749 Rom
An access to the $6000+ area will reboot the ECM.
RBob.
Re: Re: 730/749 Rom
RBob.
RBob.
I keep seeing references to it but no info.
Did this communicate with a display or tuning device of some sort?
Any other ideas on what it did, does, or could do?
Car: 81 Turbo Trans Am
Engine: 301 T
Transmission: 200-4R
I believe there was some tuning/adjustment/display hardware connected to the back of the ECM that used the addresses you describe. If you look at section 2.5 in the Turbo_P4 document, you'll see some references to that hardware. It describes what variables were available on the HUD unit for different switch positions.
Car: check
Engine: check
Transmission: check
Re: Re: Re: 730/749 Rom
Don't want that
Don't want that
Also note that the RAM addresses in the L04xx area is on the external calibration equipment.
RBob.
Car: An Ol Buick
Engine: Vsick
Don't want that
Don't want that
The HUD was just degmented LED displays, not what you'd imagine in the way of a windsheild image.
Then there was an emulator.
And a data loggin devise.
For the very early 80s it was SOTA, but primitive compared to anything we have today.
Re: Re: Re: Re: 730/749 Rom
RBob.
RBob.
Didn't know that. Tagged as such in my hac.
One more piece of the puzzle clarified.
Was hoping the routines could be of some use for modifying parameters but looks like nothing there.
Jp
