'165 for 700R4 control only??
Old Dec 11, 2005 | 12:23 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I have a complete immaculately clean 1987 305 TPI complete engine and transmission I just picked up for $115. It is going in a 1983 Firebird. The engine did not come with the TPI intake. I will return it to TPI at some point, but just to drive the car I will run a carb. I will use a 165 PCM when I put TPI back on. Can I get the 165 ECM, taking VSS input, to control just the 700R4? What are the minimum inputs that the 165 needs just to run the 700R4 overdrive and converter lockup correctly?
Old Dec 11, 2005 | 08:41 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: '165 for 700R4 control only??
How are you going to generate a TPS signal off of a carb.?.
There's a document floating around about using an ecm for ignition control, that you might try searching for.
It'll take less effort in the long run, just to wire up as much as you can, while you're in there wiring. I've been thou the *Stage* type project, and it's really easier to do it all at once, or as much as possible.
You'll need battery power, key-on, grounds, VSS, TPS, RPM, TCC out, brake light input, probably coolant temp., then you'll also have to turn off the diagnostic flags for various other items.
Old Dec 11, 2005 | 09:02 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
You have two choices:
1) do exactly as Grumpy said
2) You could also wire it up like GM did the mid-late 80's pick-up trucks that used the 700R4 without computer control. Use a vaccuum diaphram. I think TCI and some aftermarket companies even sell a kit if you don't want to figure it out yourself.
Old Dec 11, 2005 | 09:26 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I've got a working B & M control setup that is speed controlled.
Removed from my car when I went to the 730.
Worked fine, just got control by ecm and didn't need it anymore.
part number BMM-70244 at Summit. $75 (+ship) takes it
Or just do a toggle switch (possible vac switch permissive), crude and not user freindly but effective for cruising. At least until you do the TPI swap. (Will be selling mine soon too!)
Gotta make a list and do some cleaning out this spring.
Old Dec 11, 2005 | 08:41 PM
Car: 2000 BMW M5
Okay, idea. What if I use a CC quadrajet and its corresponding ECU? I know the CC quadrajets have a TPS. Did the 700R4 that would come in a 1982-84 CC Qjet'ed F body have the same 4 prong plug like the 85+ TPI 700R4s do? Does the computer from a CC Qjet'ed car have outputs for the trans that will be acceptable?
Old Dec 12, 2005 | 12:40 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
the connector is the same, im not sure without looking at a wiring diagram, but you may need to swap the pins around.
you need power from the brake switch when the brake is released to the power side of the TCC connector, then the ground side of the TCC connector goes to the ECM.
you will need the signals Grumpy mentioned above.
Old Dec 12, 2005 | 01:08 AM
Car: 2000 BMW M5
Thanks again. It looks like I'm going to use a non CC qjet and get the standalone vac. module to control TCC from a truck. There is a U pull truck yard around here with lots of chev. v8 stuff.
Hotrodboba400
Dec 10, 2019 07:07 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Doobie52
Sep 11, 2015 06:19 PM
dbrochard
Sep 7, 2015 09:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
