7747 prom
Old Dec 31, 2005 | 04:18 PM
ck76239's Avatar
Car: 1982 z28, 2007 Silverado
Engine: 350 Chevy, 10-1 CR, Comp Cams 270h
Transmission: Th350,
7747 prom
Hi Guys, I just eprom programmer, a couple of zif sockets, and a few 2732 eproms....
I took apart my 7747 ecm, and unsoldered the original eprom socket, and soldered in the new zif socket so that I could gain access to the lever....
My question is, when I removed the prom, I failed to take notice which side of the ECM the v-notch on the prom is supposed to go....
Does anyone know?
Thanks & Happy New Year!
Ck76239
Old Dec 31, 2005 | 04:25 PM
87tpi7749's Avatar
Car: 1987 Iroc, 1987 MCSS TPI
Engine: 5.7L
Transmission: 700R4 in both
Of all the ones I've used, with the limp home chips on your right, the v notch is all the way on the left. I just took a picture, screwdriver is pointing to notch.
Old Dec 31, 2005 | 05:30 PM
JPrevost's Avatar
Car: 91 Red Sled
And this would be incorrect for the 7747. For the memcal ecm/pcm's it is true but not for the older hardware.
On the 7747/8746/etc. the pin 1 should be facing the centerline of the ecm. If you installed a zif and have access to the handle then I'm pretty sure you've got it installed "correctly" where as pin 1 is closest to the lever.
Old Dec 31, 2005 | 06:32 PM
87tpi7749's Avatar
Engine: 5.7L
Cool, I did not know that. I thought perhaps they were all the same.
Old Jan 7, 2006 | 11:21 AM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
TBI ^^^^^
Front 4 legs (2 each side, side with notch) hang off the adapter and are not used on the ecm.
Old Jan 8, 2006 | 05:52 PM
ck76239's Avatar
Thanks Guys, that's what I needed to know
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
dusterbd
Sep 29, 2015 08:40 AM
BLK87Z
Sep 18, 2015 11:29 PM
Winchester1094
Sep 15, 2015 09:48 AM
