Stand-alone data logging software?
Old Jan 17, 2006 | 01:47 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Are there any good OBD 1 datalogging packages available that let you also customize the definition file?
I really dig tunerpro's flexibility on the datalogging side, but it doesnt work well on my laptop, and I hate buying something nice since itll see alot of abuse in and around the car.
Old Jan 17, 2006 | 01:57 PM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
I use Craig's old "E6" datalogger (written in Qbasic) on an old beater laptop running DOS to log my '730. I've extensively modified the output of the logger for my own tastes.
Old Jan 17, 2006 | 04:32 PM
AlexJH's Avatar
Engine: 5.7L V8
You mentioned a while back that you had a Tcl library to use read the datastream on FreeBSD, have you made any progress on that?
Old Jan 17, 2006 | 04:35 PM
AlexJH's Avatar
Engine: 5.7L V8
I also wanted to mention that I was kind of sad that no one wanted to help out on this:
http://ecmedit.sourceforge.net/
I'm thinking of rewriting it so it's a C++ library that takes plugins for different formats (xdf, ecu, xml) and then write the GUI in Python, it should be useable on old laptops.
Old Jan 18, 2006 | 09:42 AM
Engine: 5.7L TPI
It worked for my needs at the time (testing the ALDL byte write hack and the NVRAM expansion hack). Nobody was interested in the code. It's good for quick development, but it lacks speed. I translated the ALDL code to Objective-C. I can send and receive mode 1/2/3/4 ALDL packets on Mac OS X 10.4 using a USB-to-serial cable with the FTDI chip in it. I could build an ALDL data logger for OS X at this point, but my goal is to make a nice app to control my real-time programmable '730 hack (the ALDL based one using the extra NVRAM). I'm not a software programmer, with my (lack of) skills and the amount of time I can spend on my projects - this could take a long time.
Old Jan 18, 2006 | 10:28 AM
AlexJH's Avatar
Engine: 5.7L V8
I'm interested in the source, could I check it out? I've never used Objective-C so it should be a fun experience!
Falcon50
Aug 22, 2020 03:26 PM
L98GTA87
Oct 19, 2015 10:43 PM
bjpotter
Oct 4, 2015 07:48 PM
BWilcox
Sep 20, 2015 12:19 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
