noob tunner with question?
Old Jan 31, 2006 | 10:38 PM
bluechevy194's Avatar
Car: 92 c1500
Engine: 355ci
Transmission: 700R-4
a few question guys im new to the tunning world, ive had my new motor in for about a month now and have a chip from tbichips.com, its not perfect but it makes the truck run, but anyways im going to order some tuning equipment from moates.net so i can get this thing running right. my first question is when i start this thing
up it idles like crap, sounds as if it has a huge cam in it(the cam in it isnt that big, only around .450 lift and 112 lsa), then it levels out after a good 30 seconds. i need to know do i need more or less fuel durning start up and do i need more or less spark during start up?
My other problem is the engine sort of bogs or hesitates from
a dead stop, if u are at a stop light and u try to take off it will bog down at first, just only when u barly touch the peddle to get yourself moving, then it is fine through out the rest of the
rpm range. I also need to know do i need more or less fuel hear and would more or less spark help hear?
thank guys
Old Feb 1, 2006 | 10:11 AM
AlexJH's Avatar
Engine: 5.7L V8
You'll have to use a scan cable and see what the datalogs are doing to solve your idle and bogging problems.
That's once you're sure that there aren't any mechanical problems..
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
