Tunerpro 4 6E XDF w/ O2 bounds not quite right
Old Jan 31, 2006 | 11:38 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I have the 6E XDF for Tunerpro 4.xx that someone added O2 upper/lower bounds to. This gives you 3 O2 tables -- cross point, upper, and lower bounds. However, the upper and lower bound tables both have two rows for 64 values -- they start at 8 instead of zero like the O2 cross point table does. Has anyone else used this XDF and noticed this? Are just the row labels wrong or are the values incorrectly offset? If I assume the first row in the upper/lower bound tables, labeled "8" is actually "0" and offset accordingly is that correct? Is there a corrected version of the XDF w/ the O2 bounds for 6E?
Old Feb 1, 2006 | 01:54 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Pull down the 6E hack and correct them! The hack is on Craig Moates' file manager.
