Another question about AE
Old Feb 1, 2006 | 09:20 PM
ULTM8Z's Avatar
THough I'm sure it's dumb question, so please flame me AFTER giving the answer...
Looking at the AE vs Delta TPS
Why is it that the larger deltas have lower AE values? Seems counter-intuitive. I would think that a larger delta would require a bigger "pump shot" so to speak.
Old Feb 2, 2006 | 11:27 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Unless theres something unique about port fueling, the AE should increase as the delta TPS, or the rate that the throttle is opening, increases. Possible error in def file?
Old Feb 2, 2006 | 12:54 PM
ULTM8Z's Avatar
Here's the AUJP bin.
As Delta TPS increases, pump shot decreases... unless I'm reading it wrong...
Old Feb 2, 2006 | 02:46 PM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Maybe that table has to do with the amount of AE when the throttle is already open?
For instance, if you go from closed throttle to 25%, then you look at the multiplier for 0% TPS (since it started there) and give 100% of the AE. But maybe if it opens from 25% to 50%, the ECM will do only a 1/4 of the AE it would have done otherwise.
If that's not it, I have no idea!
Old Feb 2, 2006 | 08:59 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Logically, in my opinion, Kevm is correct. I added a similar feature to the efi system that I'm currently using/developing, and it works. Once the throttle is open somewhat, opening it further has less effect.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
