$58 and BPC
$58 and BPC
I know this subject has been picked apart in the past but I finally got my car back up and running (a year and a half later)with a turbo now. My BPC is set at .0725 now. The car is showing between 12.5 and 13 to 1 AFR on the wideband at idle and part throttle. If I want to scale down the fuel a little leaner across the board, do I raise the BPC number or lower it?
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Here are the formula for the correct BPC.
So If you want it to go leaner you need to lower the value.
BPW vs EGR
The correct formula is: BPC = 730.75 * (vol of 1 cyl / inj flow in gms per sec)
BPC calc:
BPC = 730.75 * (VOL / RATE)
; VOL = Vol of 1 Cylinder in liters
; RATE = Injector flow in gms/sec
; gms/sec = (lbs/hr / 3600) * 453.6
BPW vs EGR
BPC calc:
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Be careful when using that formula. That formula works well with the RR_V14.ecu file and derivatives. It will give a number like 100 or so. It will not give a number like .7025 (big scale difference). It sounds like you are using a non-TunerPro/non-Tunercat editor. That looks more like a Promgrammer number.
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
To use the formula in Tunercat use the editor and change
Edit step size 1
Minimum Table value 0
Maximum table value 255
Scale factor 1
/N.
Edit step size 1
Scale factor 1
/N.
