Cold Warm Hot Specifications
Old Feb 5, 2006 | 08:01 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
How do i find the value specified for cold, warm and hot definitons?
ie: Loop Closed Delay Timer Cold O2 Temp.
Loop Closed Delay Timer Warm O2 Temp.
Loop Closed Delay Timer Hot O2 Temp.
Old Feb 5, 2006 | 09:47 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
For $8D see this
https://www.thirdgen.org/techbb2/sho...ighlight=timer
Old Feb 6, 2006 | 05:00 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Thanks JP. I didnt understand at all what you posted but after about the 10th time i read it, i caught the division of the timer by the "specified value".
So the specified value will be the mulitplication of the timer input by me, by 2?
Specified Value=(user input timer * 2)?
Old Feb 6, 2006 | 05:09 PM
JP86SS's Avatar
Basically I was confused as to the actual time values.
there are three different timers that are used for going into closed loop when starting up.
1 for cold startup, 1 for warm, and 1 for hot.
Each has its own length of time set progressvly faster.
The hac was indicating a value = to "$0F" =15 for the "hot" timer but was shown calculated as 7.5 seconds.
The XDF was indicating 7.5 seconds for the same.
The value in the code is 2 times the actual time in seconds as it turns out. The code divides it by two when it is used.
So both are correct.
Old Feb 6, 2006 | 05:18 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
cool, thanks JP.
92firebirdguy
Sep 1, 2016 07:53 AM
Grant2k
Apr 4, 2016 08:21 AM
L98GTA87
Oct 19, 2015 10:43 PM
Racerx974
Sep 19, 2015 10:16 AM
bryan623
Sep 19, 2015 10:13 AM
