Datamaster showing "blips" of ~46ms inj dc @idle
Car: 1987 Iroc, 1987 MCSS TPI
Engine: 5.7L
Transmission: 700R4 in both
Yep, just what the title says. DM is showing "blips of 20 and sometimes 46 ms duty cycle, yes 46 not 4.6. Is this just junk in the data stream or is this possible? I'm trying & miserably failing at tuning this POS $58 749. I haven't left the idle params.
I have my own little hole in the ozone over my house with all the HC's I'm producing. Should be good for tanning this summer.
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
hey i'm in CT also, i just started working on the $58 code from $8D and it seems a lot more involved, granted i only have a 305 but it's super rich compared to the 8D i started with, but i just got my procharger and need to get it to work, if not it's $8D and the FMU
i think something is wrong with the $58 ADS file, i'm showing 6ms at idle compared to the 1.x with 8D
Car: check
Engine: check
Transmission: check
Re: Datamaster showing "blips" of ~46ms inj dc @idle
RBob.
