Help needed to retrieve bin
Old Mar 11, 2006 | 07:17 PM
87 Vette Owner's Avatar
Car: 1987 Corvette
Engine: 383 ci
Transmission: ZF 6 Speed
Axle/Gears: 4.10 Dana 44
Hi,
I am new to the Third Gen forum, but after a lot of searching, it is clear that you guys really know your stuff. The guys over at the Corvette Forum HIGHLY recommended talking to you about DIY scanning, datalogging, tuning, etc.
I have 1987 vette, 165 ECM, $32B Mask (hopefully I stated that correctly). Engine is a 383 mini ram, AFR 195 heads, 240/240 @ .050 (.580 lift) cam, and 30 lbs injectors.
I am trying to get (and then I'll need to read) the .bin file from my chip(s).
I actually have 3 chips from Formato - the original, and two others that they burned for me based on a few changes I requested (higher target idle, leaner at cold start open loop, etc). I'd like to compare the programming from each of the three. (Eventually, I'd like to learn how to program myself, but for now I just want to learn how to retrieve and view the files so I can start to understand them).
I have a laptop, serial cable, and the ECM851 software. I tried doing a "PROM dump" using the 851 software, but could not get it to work. I may not be following the correct procedure (if there is one). At one point, it looked like it was starting to dump some data, but then I got something like a "data timed out, no connection" message. It dumped about 1 KB of data into the file. I re-tried several times, but I kept getting that message.
I also downloaded the TunerPro software, but couldn't figure how to retrieve the bin file using it.
Any advice would be greatly appreciated - I am very new at this!
Thanks,
Dan
Old Mar 11, 2006 | 08:14 PM
87tpi7749's Avatar
Car: 1987 Iroc, 1987 MCSS TPI
Engine: 5.7L
Transmission: 700R4 in both
I don't know of any ALDL interface software that can read a .bin file from a chip while in an ecm. That doesn't mean it isn't possible, I just don't know if it exists.
The way I read/program chips it with a chip reader/burner. I use one from XTRONICS, Craig Moates has some really great stuff to read/burn/emmulate etc. If you need to buy one tool to scan, burn, emmulate, check out Craigs products. www.moates.net
As you progress through chip programming, you will want a way to program "on the fly" while the engine is running and be able to record your runs. I have a programmer to run the bin file "on the fly" and I simultaneaously run a data record program all on my laptop, so I can edit with the engine running and see the changes by switching back and forth between programs.
Check the stickies at the top, all the hardware requirements are listed to burn chips.
Old Mar 11, 2006 | 09:58 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
ECM 851 will not read the 160 baud datastream (which yours is). It is intended for 8192 $6E ('89 F/Y body) and $8D (90-92 F/Y-body). It will indeed read the bin through the ALDL port for those.
Otherwise, yes, you'll need a chip burner/reader to get your bin data from the chip.
Old Mar 12, 2006 | 06:51 AM
Car: 1987 Corvette
Engine: 383 ci
Thanks for the info!
I thought I read that 1986 - 1995 Corvettes were 8192 baud, but I could certainly be wrong.
At any rate, since the ECM851 software won't do it for me, it sounds like the reader/programmer is the way to go. Damn - I wasn't quite ready to go that far yet, but I guess it's now or never
Thanks for the help!! Time to check out the stickies again!
IROCZ1989
Jan 24, 2016 03:55 PM
ezobens
Aug 19, 2015 10:29 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
