duals fan ?s
Old Mar 15, 2006 | 02:29 AM
antscrd's Avatar
Car: 91 z28/2014 charger
Engine: 350/ v6
Transmission: 700r4/ auto
duals fan ?s
i apologize if this is the wrong place to post this...
1. on ANY of th yrs with tpi and dual fans, can both of the fans' turn on/ off temps be controlled by the computer? iirc, the first fan is controlled by the computer, and the second by the temp switch. if i'm wrong, could be the lack of sleep. oh yeah, and the ac turning on controls one. the reason i'm inquiring is because i had a chip tuner tell me that he could set both fans' parameters in my computer?
2. if the above is true, are the fan switches still necessary?
thanks in advance.
Old Mar 15, 2006 | 07:47 AM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
Both can be controlled by the computer....look for a post by Glenn91L98GTA where he tells you how(search is down or I would have linked you to it). There is some rewiring of the ecm connector involved tho..nothing major just swaping some wires.
No the fan switch is not required but I would leave it in as a backup just in case.
Old Mar 19, 2006 | 02:00 PM
89Vert's Avatar
Car: '89 Iroc Vert
Engine: 355 TPI
Transmission: T-5(for now)
Axle/Gears: 3.45 9 Bolt
my brother has an 88 with dual fans,
his ecm only can control 1 fan the other is controled by a temp switch,
my 89 only has a single fan controlled by the ecm,
90+ that I have done work on have dual fans both controlled by the ecm
Old Mar 20, 2006 | 03:12 PM
91L98Z28's Avatar
Car: Z28
this may be helpful
https://www.thirdgen.org/forums/diy-prom/182538-second-cooling-fan-control.html
Old Mar 21, 2006 | 06:02 PM
antscrd's Avatar
Engine: 350/ v6
thanks 91L. appreciate the link since search is down.
ZEEYAA
Apr 16, 2023 08:29 PM
sheachopper
Jul 31, 2019 11:27 AM
91 SrS
Oct 7, 2015 04:32 PM
Fanatic1074
Oct 2, 2015 03:47 PM
zman1969
Oct 1, 2015 11:09 AM
