wb hack tunerpro aldl z69?
Old Mar 19, 2006 | 01:55 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i'm using the axxdwb bin that has the wideband hack from Z69, i'm trying to figure out how to add the min iac to the aldl definition, i'm having no luck as i'm not familiar with the ads files. can anyone help?
Old Mar 19, 2006 | 07:38 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Its already there, you don't need to do anything.
What was done is that the "word" that used to be the min IAC is now pointing to the WB output.
Any scanner that has the display for IAC min is now displaying the WB output from 10-20 AFR in that spot. (Just ignore the label)
Old Mar 19, 2006 | 07:43 PM
JP86SS's Avatar
In case you don't have it and need to add it.
This is for the A100 definition ($8D)
You can name it "WB AFR" if you like also.
Mark_ZZ3
May 24, 2018 01:02 PM
2012sergen11
Oct 13, 2015 07:38 PM
ULTM8Z
Oct 2, 2015 01:25 PM
z28joe2
Sep 28, 2015 05:54 PM
greenyone
Sep 8, 2015 08:41 PM
