another quick question
Old Mar 24, 2006 | 09:52 AM
longhorn450's Avatar
Car: 1990 Trans Am
Engine: LB9 305...350 or 383 coming soon
Axle/Gears: 4th gen 3.42
If I use the Craig Moates adapter with a new EEPROM, can I take out the entire adapter and use the stock EPROM?
Old Mar 24, 2006 | 04:22 PM
Car: 1990 Trans Am
What I mean is can I use the adapter with my own EEPROM, and then completely take out the adapter and chip and regain full use off my stock EPROM?
Old Mar 24, 2006 | 04:45 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
Yes, that's what the adapter is for. Just FYI (you may already know) the adapter requires the use of the stock memcal; just bypasses the EPROM.
Old Mar 24, 2006 | 08:02 PM
brutalform's Avatar
You also might want to consider an Aries ZIF. They are inexpensive, and save on wear on the adapter. Hard to tell in the ECM pic, but the ZIF is there, along with the stock memcal, at the top of the adapter.
Attached Thumbnails another quick question-s2_0.jpg   another quick question-picture-016.jpg
Old Mar 24, 2006 | 10:53 PM
Car: 1990 Trans Am
One more thing, when running the WinBin Editor, you must input a Bin File and an ECU File. Ididn't read anything in the Intro To Prom Burning article about one being needed. I have the BIN File but where does the ECU File come from?
Old Mar 25, 2006 | 12:09 AM
Car: 1990 Trans Am
I now know what the ECU (Calibration) File is but I dont know where to get one. I need one for a 1227730 ECU. The DIY-EFI website wont work and the one from the area51 website won't work after I unzip it. It says Grid32 is not working right. Where can I get one that will work?
Old Mar 25, 2006 | 01:48 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
www.moates.net or www.tunerpro.com (in teh file downloads areas)
Old Mar 25, 2006 | 02:00 PM
Car: 1990 Trans Am
Ok, I found the ecu file I need, but how do i get it onto the WinBin ECU File screen?
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
