Datalogged WOT.. advice?
Old Apr 2, 2006 | 08:42 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Just wondering if anyone has any advice.
Looks like it is REALLY rich at WOT even in the higher RPMS. I am using the 89' vette ARAP file with the wideband02 hack. I have the Innovate LC-1 tapped into my ecm to datalog. The Wideband AFR shows up in the "Target AFR" cell.
I thought I would be really lean at WOT but I guess not? But it does look like it goes pretty lean for a split second as I am pressing the throttle down.
Anyway, here is a graph/log.
Also have no idea why I'm getting so much knock retard/knock count at the lower rpms. I'm thinking it might be the aldl diagnostic mode or???
http://members.shaw.ca/thewanderers/wotapril1.csv
This should be able to be opened with Excel.
Old Apr 3, 2006 | 11:36 AM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Ditch ARAP's timing table for your stock table until you figure out where all those knock counts are coming from. You are not maxing out the MAF, which is also odd with your combo, so raise the commanded AFR using the PE vs. RPM table.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
ULTM8Z
Oct 2, 2015 01:25 PM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
