Anyone have BLCL bin? or link to it. for 16168625 PCM
Hi, just received my stuff from Craig Moates and just figured out I needed a HDR1 adapter to pull the stock bin off my prom before I can fire up the ostrich . Found a bunch of other bins for the 16168625 but all seem to be for 4.3 or 5.0 or other. Mine is 93 5.7 , 4L60E 7200lb gross C2500.
Thanks, Jon
Thanks, Jon
Thanks, Jon
Thanks, Jon
I have quite a few '8625 bins.
I'll check when I get home..
Send me a PM or email if I forget ;-)
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
I have a BDJY bin for a 93 5.7 Z71 pickup 4L60E 8625 ecm if you want it. Let me know how to send it if you need it. I took harness/ecm out of truck to use for myself in streetrod pickup project.
Hi, Sorry for the late reply just got my laptop back from dell, it was gone for a week for a new motherboard. I ended up buying a new prom with BLCL from Rockauto.com , was $68.00 delivered. I put it in a extra pcm i got off ebay and the truck runs fine with it . I wanted to keep the origional pcm and prom in reserve in case I fried something with my begginer chip burning. I read the new prom with moates flash and burn and tunerpro RT and tried to burn the bin to a blank chip and put it in the pcm with a moates gp1 adapter but the truck will hardly run , I think I dont have the addressing right on the new chip. Now I will go back and read the directions! When I get a good chip going then I will put it in my ostrich and start making some changes and have some fun. Anyway just wanted to tell you guys what im up to, I will play with it some more and read up, I will ck with you all later if I cant get anything going. Thanks, Jon
NBrehm
Aug 25, 2015 11:49 PM
