Does $8D use VSS and P/N for anything fuel related
Old Apr 7, 2006 | 09:13 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Ni hao,
Quick questions about rumors I've read, and would like clarified -
Just don't want my dad to fudge his 91 TPI motor in the 79 Malibu in its current configuration.
1) Other than a speed limiter, does $8D use VSS or P/N for fueling (like allowing PE mode, DFCO, etc...)
2) What could be some problems without running them (other than TCC lockup, and idle control problems). Fan probably runs at all vehicle speeds, but that's no biggie.
Xie xie
Old Apr 8, 2006 | 02:37 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
P/N I cant comment on, always had a working one in given app, so I'm not sure there, never had to look into it. There is something about it I remember though, like maybe locking inot one cell or limited cell travel?
The VSS stuff is partially tied into the purge, throttle follower routines, etc.
Can get around some of the IAC stuff by bumping it up at the actual idle screw to eliminate the stalling. Might make for some herky jerky driving when on and off the gas, might not be as noticeable if your running non lockup.
By the way a newer 'Bu column would go almost right in and get u a park neutral switch to boot.
later
Jeremy
1992 Trans Am
May 10, 2023 07:19 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
86IROC112
Aug 21, 2015 07:20 PM
Jk_Under
Aug 17, 2015 03:08 PM
mizz0313
Aug 12, 2015 06:45 AM
