EBL-fan settings
Old Apr 18, 2006 | 06:49 AM
liquidh8's Avatar
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
EBL-fan settings
Well all, got in the taurus fan. I was wondering if anyone know why it comes on @ 74 C, I tried changing the min/max CTS value, I set the MPH override to 55mph, but even if I am doing 70 mph it still comes on after 74 degrees C. Any ideas, I've been emulating to try changing the setting real time and can't seem to get er done!
Old Apr 18, 2006 | 07:07 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Check the fan overide CTS, I believe if you get to that temp, the fans come on regardless. Also check that your VSS is working properly.
Old Apr 18, 2006 | 09:08 AM
liquidh8's Avatar
Transmission: 2004R
yup, the VSS is fine, my speedo is 10mph fast, so I bumped up the speed shut off to 55 mph. The fan override temp is set to 90 C, that's why I don't understand why it is coming on @ 74 regardless.
Old Apr 19, 2006 | 07:58 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Was wondering if you have this figured out. One other item that will force the fan on is a CTS malfunction. A/C active will also do it, but only under the MPH cutoff.
RBob.
Old Apr 19, 2006 | 08:56 AM
liquidh8's Avatar
Transmission: 2004R
RBob, the CTS seems to be fine, That's how the ecm would see the actual engine temp right, the gauge matches the ecm's reading for the coolant temp. I also have the a/c off, it isn't charged anyway. I have checked to see if it goes on and off with the a/c turned to on and it does. I have a spare CTS somewhere, but I believe it is fine. I'll ohm it out, and if need be swap it out with another. But I don't think that is it.
Old Apr 19, 2006 | 01:00 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
ECM temperature is from the CTS sensor. With the ECM is reporting correctly I then I agree, not the sensor. If you want email me your BIN. I'll check it out and get back to you.
RBob.
Old Apr 19, 2006 | 04:35 PM
liquidh8's Avatar
Transmission: 2004R
ok, lemme get it off of the laptop and I will send it to you.
Old Apr 21, 2006 | 08:02 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
OK, found the issue with the fan temperatures. In the ECU/XDF I used the old equation, not the new one. So the temp's are close, but not correct. If one wants to correct it themselves here is the info.
In two locations for the fan: over ride, and the lower/upper values. Change the offset from -5 to -40, and change the multiplier from 0.625 to 0.750.
That will take care of it. If any EBL user would like updated ECU/XDF's send me a PM or email and address and I'll email new copies with the corrections.
RBob.
Old Apr 21, 2006 | 09:31 AM
liquidh8's Avatar
Transmission: 2004R
thanx RBob, PMed you my email addy. Thanx for looking into it.
Old Apr 21, 2006 | 06:43 PM
liquidh8's Avatar
Transmission: 2004R
update:
I changed the formula and it works now. At least the override does. The fan doesn't come on anymore @ 74 C when driving down the road. Though the min/max I'm not sure. When it was warming up I sent the min to 30 C and the fan didn't come on.
Old Apr 21, 2006 | 07:19 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The min is the turn off CTS, the max is the turn on CTS. So, once above the max, the fan turns on. Then once the CTS falls below the min the fan turns off. {wow, I need sleep}
RBob.
Old Apr 21, 2006 | 08:00 PM
liquidh8's Avatar
Transmission: 2004R
DOAH!!! I'm an idiot, must have my backwards thinking cap on to day. I knew that too!!
82tabird
Dec 21, 2015 10:22 PM
lt1z350
Sep 29, 2015 01:50 PM
hydrolic144
Aug 29, 2015 04:14 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Aug 24, 2015 06:52 AM
mustangdmurder
Aug 21, 2015 07:17 PM
