EBL, LM-1 output incorrect??
Old Apr 25, 2006 | 05:37 PM
liquidh8's Avatar
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
Help, just borrowed my friends LM-1 and the wb data on the WUD is lower than what is on the LM-1 display. What am I doing wrong? And do I need to hook up the analog output to where the original o2 was?? Or can I just run from the wb with the original o2 diconnected?? I guess there is a voltage settin I have to do on the analog output into the ebl to get it to trace right with the lm-1 Anybody know?? I'm working on this right now. Thanx
Old Apr 25, 2006 | 06:13 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The LM-1 requires the analog ground to go to the EBL board. This is from the 3-pin headphone jack (LM-1 power goes to chassis ground). Then program the LM-1 analog output for 1 to 2 volts, and 10 to 20 AFR. That should do it.
RBob.
Old Apr 25, 2006 | 07:07 PM
liquidh8's Avatar
Transmission: 2004R
Thanx, that's what i did after you posted. It's not dead on, but it is close. Thanx rbob. what should ido for the narrow band? Should I leave the settings the way innovate left them??
Old Apr 26, 2006 | 12:31 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If you are using the WB for VE tuning, lock out closed loop by setting the temperature enable high. Then it won't matter what the NB setting is.
RBob.
Old Apr 26, 2006 | 04:24 PM
liquidh8's Avatar
Transmission: 2004R
cool, did that
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
6998poncho
Sep 25, 2015 02:56 PM
85Special
Sep 3, 2015 04:21 PM
