1227747 ecu using large camshaft?
Old May 3, 2006 | 08:16 PM
michal_larson's Avatar
Anyone use the 1227747 ecu with a camshaft?
Old May 3, 2006 | 08:25 PM
i cannot get my car to cut out @ WOT. i currently have the PE AFR @ 9:1. at least 20 psi using stock injectors. could i possibly have messed something up in the PE Temp Threshhold?
Old May 4, 2006 | 07:18 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I don't understand what you mean by cut out at WOT. Are you checking that there isn't a fuel delivery issue by flooding the engine out?
RBob.
Old May 4, 2006 | 04:23 PM
nah, what im sayin is if i cant drown out the motor @ 9:1 AFR then tunning the thing would be impossible, but i tested it out today and it hurles black smoke and slows down when i initiate PE. So now i can start tunning. Before my 02 sensor was lean all the time, now ive doubled my fuel pressure, i can tune it. before the fuel pressure, i could run 5:1 AFR and it still ran good. so i assumed i was starving for gas.
Old May 4, 2006 | 08:46 PM
elkabong's Avatar
Car: 84 Vette
Engine: 383 XFire
Have you adjusted your base pulse width (BPW)?
Old May 4, 2006 | 09:31 PM
MY BPW is 148 as for a 305 with #55 injectors
stock BPW was 135 for a 350 with #62 injectors
Old May 4, 2006 | 09:40 PM
here is the file
File Type: zip
Old May 4, 2006 | 09:41 PM
305 *cross-fire* should have #55 in them requiring the *148* BPW instead of the *135*
MrPackstin
Oct 25, 2017 08:09 PM
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
KO1
16
Oct 15, 2015 05:00 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
Damon
Sep 26, 2015 04:29 PM
