odd ball ecm?
Old May 3, 2006 | 11:11 PM
bluechevy194's Avatar
Car: 92 c1500
Engine: 355ci
Transmission: 700R-4
odd ball ecm?
hey guys i happen to have an odd ball ecm #16146299 ($99), out of a 92' c1500, they only used this ecm one year, sadly i cannot datalog since winaldl doesnt support this ecm and i cannot find an ads file for tunerpro r/t. So i guess i have to switch over to a differnet ecm, my questions are will ecm #1227747 ($42) or #1228746 ($61) work with my application, i mean just plug right in, i dont want to have to re-wire anything or get a new wiring harness? My other question is if both of these are compatable, which would be the better one to use?
Old May 4, 2006 | 02:00 AM
HaulnA$$'s Avatar
I have actually gotten WinALDL to datalog the 16146299 ECM and $99 mask. I forget which ECM selection in WinALDL actually worked but if you play with it, it will work well enough to do what you want. HTH
Old May 4, 2006 | 08:29 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
That PCM was for a manual, if I recall correctly, so for Off Highway Use, the 747 should be fine. Might even go to an EBL one, and then have some good code to run in it. And the EGL comes with some dynamite HUD software.
Either will take rewiring, but the payoff is well worth it. You can't imagine how good the EBL is.
Ed1LE
Sep 30, 2018 09:14 AM
Mark_ZZ3
May 24, 2018 01:02 PM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
