Best definition to use for TPI swap, 32, 32b, 6e? What broadcast code to start with?
Old May 4, 2006 | 09:20 AM
Nathan Plemons's Avatar
Car: 1992 Chevrolet Corvette
Transmission: ZF-6
A friend of mine is soon going to be placing a TPI setup on his IROC and replacing the carb that he's had lots of problems with. The TPI setup we are hoping to aquire is off of a 305 and the year is undetermined as of yet. I know it's a MAF setup with the 165 ECM. He's gonna want me to tune this system, but I need to make it run first. My experience is primarily with speed density LT1's, so I need some information about these systems!
I've been doing some looking and I see that the 32, 32b, and the 6e definitions should all work with the 165 ECM. What are the pros and cons of one definition file over another? I believe that the 6e eliminates the cold start injector? Is this all it does? The TPI system we're getting will likely still have a cold start injector but that doesn't mean we have to use it.
Also since the TPI computer we'll be getting is for a 305, that's obviously gonna be less than optimal, I'm gonna want a different calibration before I even start. So, in addition to 32, 32b, or 6e, what would be the best broadcast code to start with on a 350 with a manual trans?
Old May 9, 2006 | 02:04 PM
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
Transmission: TH-700R4
Axle/Gears: 10 bolt 4:11 posi
Broadcast code
If you havent read this already then you may want to look at it "The Prom Tuning Guide" I think it help answer alot of the concerns you have. In my opinion the $6E is a much better mask to use (more versatile) and aside from injector size and timing the 305 and 350 use the exact same setup.
$750 L98
Feb 1, 2025 02:25 PM
xodus2002
Jul 17, 2020 09:08 AM
FormulasOnly
Jul 23, 2018 08:47 AM
85 Jimmy
Sep 30, 2015 07:56 AM
lethaldomestics
Sep 21, 2015 01:18 PM
