dead spot at 1500 rpms
Old May 25, 2006 | 04:48 PM
Ronny's Avatar
ran OL and CL. fueling in OL is giving me a 122-124 BLM when verified in CL. so plenty of fuel in tune at 1200-1600 30/50map. i ran a .bin at 126 BLM CL. issue is both tunes at 1500 rpms in any gear(1-5) shows on WB 20/1 A/F. car slows down and struggles to pull load. issue is 1500 rpms under load and 1500 rpms with little load in lower gear. once i hit 1600 rpms will accellerate and A/F moves to 15/1 CL or 14.5/1 OL bin. if i accellerate briskly off idle it is a non issue. if i accellerate ever so slowly i hit the dead spot.
spark is 21 d at idle and moves to 26 deg at 1400-1600 rpms at 50 map and dropping to 20 at 1400-1600 rpms. dont think spark tables can affect A/F on WB however !
i posted this earlier in tuning season. Grumpy felt reversion is not the issue as it occurs at peak TQ i think he suggested. anyway in OL i dont think reversion can affect the issue as fueling in non 02 sensor related. fueling is set in tables and it gives what is commanded. plus i am rich ++ in OL.
what do you think?
Old May 25, 2006 | 06:47 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I think that you have discovered a drawback of the 8 x 9 VE table. It really is that simple.
You can try reducing the SA several degrees in that area. Good possibility that will make the dead spot worse.
RBob.
Old May 26, 2006 | 01:00 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Are you switching between async and sync? Just a thought.
Somehow though, I'm trying to think of what ignition problem is causing it, like cracked plugs or something strange like that.
Old May 26, 2006 | 06:45 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Originally Posted by Ronny
what do you think?
I think some experiementing needs done. Engines can have areas where they *struggle* to get up and going. That and you might have to wind up with some hills, and vallyes in the timing, and fuel tables. Don't *think* that they should all be smoothly transistioning up or down. Some times, you'll have an odd entry or 3.
Old May 26, 2006 | 08:57 AM
Ronny's Avatar
well i suppose it wont make much diff as i am going EBL with prominator very soon. like next week. picking up a 8746 and mailing to Bill tues. that may be a cure for some of my ills. odd thing is a rich BLM in Cl and rich in all fuel cells around that rpm/map area yet WB dont lie it is spiking lean.
i was thing this AM that the header collector flange to ext pipe is constantly loosening up. would air leakage into header cause that?
db057
Apr 28, 2019 07:45 AM
Amillionoh7
Sep 11, 2015 11:36 AM
Stroopwafel
Sep 11, 2015 06:38 AM
blackandblue02
Sep 10, 2015 08:19 PM
TheExaminer
Sep 6, 2015 11:40 PM
