Highway cruise miss...
Old May 31, 2006 | 09:12 AM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
$8D occurs around 1400 to 2000rpm. At about 40 to 50kpa. You can really feel it when the TCC is locked cruising down the highway at about 45-55mph. The car bucks and the tach will bounce. Its a miss somewhere. I added fuel to the area, removed fuel, added timming, removed timing, added fuel and removed timing, added fuel added timing, etc. No change at all the bucking is still there....what am I missing?
Old May 31, 2006 | 10:14 AM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
EGR?
Old May 31, 2006 | 10:30 AM
Car: 1989 Iroc-Z
Engine: 350ci SBC
running a HSR...dont have one....
Old May 31, 2006 | 10:53 AM
Car: 1989 Iroc-Z
Engine: 350ci SBC
what are you guys with similar setups running for cruise timing?
Old May 31, 2006 | 11:36 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
The only thing that comes to mind is low trans pressure not holding the TCC firm enough? Not sure if thats possible. The MAP reading may bounce when the converter slips and the load changes while you are steadily cruising.
The Tach bouncing part is the one that indicates the engine is speeding up and slowing down but very quickly and acting like a miss. Strange place for a miss to happen if air, spark and fuel can't fix it.
Do you have a log of this you can post?
Do you have hiway mode enabled?
The stock 16.1 AFR may be too lean for you in that area.
Old May 31, 2006 | 10:08 PM
First/Thrid Gen's Avatar
Car: 68 Camaro
Engine: 5.7 TPI
17 to 1 at 2000rpm and you start getting into missing on cruise. (45deg timing).
The commanded afr can be as much as 2. out from what the wide band says. It gets closer as the computer learns the intergers - but after a chip burn say, it may take 10 miles before it runs at commanded.
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
tattmann
Sep 27, 2015 05:20 PM
