I'd appreciate some help with this
Old Oct 6, 2000 | 12:27 PM
Blade's Avatar
Hey guys I'm ready to order my PROM burning equipment right now. I decided to get the Pocket Programmer fron Transtronics for $130 bucks. What exactly do I need to order to make a custom chip for my 92 Z28 ? Any adapters needed or does the chip fit in the socket on the programmer ? Also... will ordering TunerCat for 69 bucks help me any ? Does TunerCat have support for my ECM ? Thanx a lot for any feedback you might have.
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Oct 6, 2000 | 02:38 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
The PROM burning article in the tech article section of thirdgen.org explains the complications of the MemCal and the burner and the various methods to program a chip for a MemCal equipped car.
TunerCat doesn't tell you what to change for your car. They only supply support for explaining what a particular button on the program does. Download the demo and you'll see what I mean. Go to TunerCat's website and it tells you what ECM's it supports. The '92 730 ECM is supported.
I would recommend that you read the article because the article along with its links will explain everything you just asked.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.587 @ 107.97mph (1.710 60ftr) on the long runner setup.
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels. Stock Wheels. No Weight Reduction.
Gunning for NA 11's with the MiniRam II and Hooker LT Headers.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
