O2 question
Old Jun 16, 2006 | 01:21 AM
scott92RS's Avatar
Car: 92 Firebird
Engine: 350 TBI/LT4 cam
Transmission: 700R
O2 question
Is it normal for O2 sensor output to read 0.004mV during while crusing til I let off the gas? Most of the readings is above 0.450mV I increased my fuel pressure so I won't run lean up top until I change to a hi flow fuel pump during a rearend swap. I hope it just a bad sensor. Thanks
File Type: txt
Old Jun 16, 2006 | 01:53 AM
91L98Z28's Avatar
Car: Z28
I have no idea how you generated that data, but I suspect it's doing a calculation of some sort without enough logged data to make for an accurate calculation/result. or maybe it's just some kind of rounding error (0.004 is very close to 0) in the program you used.
Either way I doubt it's an accurate representation of what's actually going on.
looking at actual logged frames in sequence will be very helpful for you in this case. during closed loop cruise, you should see o2 sensor voltage jumping all over the place generating cross counts.
Old Jun 16, 2006 | 02:51 AM
scott92RS's Avatar
Car: 92 Firebird
Transmission: 700R
I was datalogging with winaldl program.
Old Jun 16, 2006 | 06:16 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
That's an incredibly hard way to read the O2.
The O2 voltages flucuate as the ecm tries to toggle across 14.7:1 to maintain an AVERAGE AFR of 14.7. So you should see it moving above and below .45v.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
