Scanning Software
Old Nov 8, 2000 | 08:16 AM
Scott 87 IROC-Z's Avatar
Car: 87 IROC-Z28
Engine: 377ci, Brodix Heads, Solid Roller c
Transmission: 700-R4 w/ Yank ST3500 Converter
Scanning Software
It seem's as if there is alot of information on tuning, and the hardware needed to tune yourself. But what about good scanning software for f-body's older than 90. Datamaster only supports 90-92. What is everyone else using for their 87 TPI cars?
87 IROC-Z 305 TPI gears, exhaust, converter
14.70 at 94.1 mph with 1.90 60'
Old Nov 8, 2000 | 11:14 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
I most often just use Diacom+.
Pricey, but good coverage for doing old and new stuff
Old Nov 8, 2000 | 11:17 AM
Blade's Avatar
I think Diacom + is the best also. Pricey but WELL worth it
Old Nov 8, 2000 | 11:37 AM
Car: 87 IROC-Z28
Yes. I know of Diacom $300+, Ease $300+ and Autoxray with the pc-link $275+ but was just looking for something cheaper.
Between Diacom, Autoxray and Ease, which one do most suggest?
Old Nov 8, 2000 | 08:32 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
I started out with Diacom. It is DOS based, not real fancy. Works good on old, slower computers. I wanted a Windows based scan tool, so I looked into the Ease Tool. I bought the personal plus version. It is easy to use, lots of bells and whistles, good recording and playback abilities. It cost more than Diacom, but it is a little more high tech. You can use it on any GM 82-95.
Let me know if you need more info.
Best ET 14.413 @95.57 without
pulling valve covers or manifolds.
Also with stock 2.77 rear end!!!
Old Nov 10, 2000 | 08:32 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Diacom is the only one, IMO
Just so versitle.
The best is yet to come, but might be a while. You'll have to cut the ecm case and get to the edge board connector, and pick up the actual bus there.
I have a Direct Scan that uses that and you would never beleive how good it is.
Fool around with something like www.chuengineering.com
If you want a real file to run on it holler.
you can set the scan rate from 4-18 frames per sec. runs DOS, is cool
Old Nov 10, 2000 | 09:13 PM
gravitar's Avatar
I opened one of my '165s for curiousity's sake, and was a bit intrigued by the edgecard. Not that I didn't expect it to be there, its pretty common for mass-production boards to have an card edge for plugging in ICE testers for burn-in and field testing. What all do you get on that bus, EVERYTHING? As in, full data/address/control busses?
And what is the scheme for polling the data at a faster rate, you can't lock the bus and do a DMA transfer can you?
1992Z28!
Nov 19, 2015 07:33 AM
RGB2015
Sep 20, 2015 09:26 PM
Deemax
Sep 12, 2015 06:53 PM
92firebirdguy
Sep 10, 2015 10:33 PM
86camaroman201
Aug 19, 2015 04:52 PM
