Programming Primer
Old Nov 14, 2000 | 12:33 PM
rwelch's Avatar
Programming Primer
Forgive the basic nature of this question but I've read a lot of stuff on this board and in the tech section and on the gmecm site and there seems to be some confusion, on my part anyway, on terminology. I'd like to get involved with chip burning but I sure don't want to start out w/a misunderstanding of the basics.
There are ecu, tdf, bin, etc files out there - are these merely file extensions used by different editors for the same code? If so, can someone provide a fairly complete listing? If not, I need an explanation of the different file types.
Is the "calibration file" different from these files?
What is "ARAP?"
I'm sure one might be able to dig this out of all the info available but it would be nice to see a concise explanation in just one place.
Old Nov 14, 2000 | 03:31 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Reading PROMs will produce an image of your PROM stored in a file with a .BIN extension (binary). It is this binary file that must be modified in order to change things such as fuel and spark parameters.
This binary file needs to be interpreted appropriately in order to read/change the specifics. In order to read the bin appropriately the Editor that you are using must have the appropriate calibration file (aka definition file) loaded.
WinBin's definition file is a .ecu file
TunerCat's definition file is a .tdf file
GMEPro's definition file is a .epe file
ARAP is a MemCal ID. There are many different MemCal IDs specific to the make/model of your car. See Ludis' site at http://www.cruzers.com/~ludis/ for MemCal IDs.
More specifically, ARAP is the PROM image used by GM when handing over a MAF car for testing purposes by Magazines.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's after installing Hooker LT Headers and reducing weight.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Nov 14, 2000 | 09:25 PM
gravitar's Avatar
"More specifically, ARAP is the PROM image used by GM when handing over a MAF car for testing purposes by Magazines."
Can you expand on that a bit? Does that make it good or bad? (I would guess good, since everybody uses it)
Old Nov 14, 2000 | 09:27 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
TRAX, your the MAN.
I myself was wonering some of the same stuff. I want to start burning my own chips also. Since the guy who did mine passed away.( JIM FORMATo out of tampa fl.)
Anyways THANKS for the great info.
Chris
1992 25th Anniv Z28 W/383 Stroker
536 RWHP 569 FT LBS
(chassis dynoed at Ramsies Perf.)
www.go.to/TPI383
djmarch
May 8, 2016 11:32 AM
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
ULTM8Z
Oct 2, 2015 01:25 PM
f-bodyz28
Sep 2, 2015 05:03 PM
bdads
Aug 24, 2015 06:01 PM
