Corvette/Camaro/Firebird Chip Question
Old Nov 16, 2000 | 10:33 AM
vic383's Avatar
I have a very basic question and after searching the previous posts I could not find the answer. I need to know if the Proms from a Corvette/Irocz/TA are the same for a 1989 TPI automatic tranny setup.
As I read other posts, I see there is only 1 bin file per year, $6E file for the 1989 TPI.
So can I use a 1989 350 TPI/Auto chip from a Corvette in my 1989 Irocz TPI/Auto ??
Vic
Old Nov 16, 2000 | 01:38 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
They used different PROMs, mainly because the Corvette had aluminum heads and the F-bodies had iron heads. With their different thermal properties and higher compression in the Vette engine, the timing tables were much different, as well as a few other things I'm sure. It will work, especially if you're using the bin to start with and will be modifying to suit your engine...
Greg Westphal
'87 IROC 305TPI/A4
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
