Need help with diagnosis...
Old Nov 13, 2000 | 03:19 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
I recently swapped out the 1228063 ECU in my '88 TBI Camaro with a junk yard 1227747. As the directions I recieved from people on this board who have done the swap I cut C-15 and D-15 and swapped A-11 and D-02. I programmed a PROM, verified it (both with the programming software as well as writing the PROM back to the hard drive and loading it into CATS and looking for changes), and placed it into the slot. I also put the Calibration Pack that I purchased into its slot. When I tried to start the car the injectors sprayed so much fuel that it was drowning the engine and it wouldn't start. The SES light was also on. I plugged in the ALDL scanner and scanned for codes. The ECU was throwing two codes: "PROM Error" and "Calibration Pack Missing". What do I need to do? Is this ECU bad? Is there some way to test it before going to the dealership and forking out $214 for a new one? I'm seriously considering converting to carbeuration, but I'd much rather get this fuel injection working correctly.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Nov 13, 2000 | 05:00 PM
Brent's Avatar
Not wanting to sound insulting but, are you sure you have the calpak and prom installed in the proper direction? There should be a tiny number 1 on each of the sockets. The notch in the chips goes to that end. Disconnected the battery while installing the 2 pieces?
If the ECM is junk, the yard should give you another.
just for reference, calpak for a 350TBI 7747 is part# 16060836, the 305 may be the same.
Don't give up yet.
Old Nov 13, 2000 | 06:23 PM
Mark305TBI's Avatar
Yeah, they're oriented correctly. The PROM's are oriented with the notches facing the same direction (which is where the (1) is). I guess the Cal-Pak is oriented correctly, it was in the carrier when I bought it and I haven't removed it.
-Mark W.
[This message has been edited by Mark305TBI (edited November 13, 2000).]
Old Nov 13, 2000 | 06:41 PM
Mark305TBI's Avatar
Well, I just disconnected the battery, re-installed the PROM and cal-pak, reconnected the battery, and scanned for codes. The scanner came back "No Trouble Codes Found" but the SES light was still burning and it still won't start. I didn't get to look at the injectors to see how much they were spraying, but judging from how the car acted (and how it smelled after I got out) I'd say it was just more of the same.
-Mark W.
Old Nov 13, 2000 | 09:42 PM
Brent's Avatar
I guess you have a bad one. Isn't the first time. I had one where everything looked normal but it wouldn't fire the injectors...
Second one from the yard worked just fine.
Maybe open the case up to see if there is any garbage inside. Not that it will fix anything, maybe give you some peace of mind. I hate not knowing what is wrong.
g'luck,
Brent
Old Nov 15, 2000 | 03:16 PM
Mark305TBI's Avatar
Well, I got a new ECU and I'm still having the same problem. I've about had it.
-Mark W.
Old Nov 15, 2000 | 11:56 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
-Mark W.
What BCC are you starting with?
Send me a copy of the bin your using, dunno sounds like the chip isn't right for some reason.
This was running just fine, and then suddenly took a dump, when you changed ecms?.
Can you grab a prom for it locally?.
Old Nov 16, 2000 | 03:00 PM
Mark305TBI's Avatar
I've been kinda suspect of the PROMs. I'm wanna test it with a PROM that I know for a fact is good before I throw it all in the toilet. I'll e-mail you the .BIN I'm trying to use.
-Mark W.
Old Nov 16, 2000 | 03:02 PM
Mark305TBI's Avatar
I need your e-mail address.
-Mark W.
Slade1
Jul 23, 2002 07:40 AM
