egr bypass
egr bypass
can i burn a chip with tunercats to disable my egr if so what all do i need to chang and how do i do it
92 b4c 305 t-5
ported plenum
58mm TB
dynomax headers
msd coil
adjustable fuel regulator
air foil
K&N
TB coolant bypass
smog pump bypass
worldclass t-5
custom built y pipe
hi-flow cats
flowmaster
hurst shifter
3.73 rear
92 b4c 305 t-5
ported plenum
58mm TB
dynomax headers
msd coil
air foil
K&N
TB coolant bypass
smog pump bypass
worldclass t-5
custom built y pipe
hi-flow cats
flowmaster
hurst shifter
3.73 rear
All you do is set the EGR on/off TPS values to 0% and disable EGR Diagnostic in the ECM switch table.
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
http://www.truspeed.dhs.org/Members/...dmondIndre.htm
92 Z28 L98 350
