what are advanatges of swapping ECM's
Old Nov 23, 2000 | 10:57 AM
rsilver's Avatar
I have a 8746 ECM in my 91 RS. I will be swapping my 305 to a 350 (sooner or later) and I wonder what if any advantages there are to swapping to another ECM, say a 8747 from a truck or some other ECM?
Troy from Howell EFI also said that the Truck computer would be better if he made me a custon chip but my existing 8746 would work. So, Whats the difference, what should I use if I swap and what are the advantages?
My goal is to get the 350 optimized when I do the swap. Once that is done, I am just gonna drive it if that makes any difference.
I really appreciate this. Good stuff to know while you are cookin turkey on thanksgiving......bob
91 camaro RS L03 convert,
t-5, ultimate TBI mods,TBI spacer,SLP 1 5/8 headers,
3"cat back, 3.42 torsen posi,alston SFC's,Global West LCA relocation brackets
Old Nov 23, 2000 | 12:24 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
The 747 is totally "known", it has been fully mapped out and all the items that can be changed are established. Given time you can take a 747 to any level of perfection that you want. Their are just a half dozen or so ecms that are well documented like that. It's also, slightly simplier since there is no IAT sensor.
Makes for an excellent chip for the novice.
Also, with having a few less bells and whistles, makes learning things alot easier. FWIW, I've done a bunch of chips, and thought the newer the better yada yada, but I've been working on an older ecm (C-3 series like the 747), and it's actually a real good ecm.
The only down side to the C3s is the Serial Data is slow. But, hopefully that will be changing..
Old Nov 23, 2000 | 03:20 PM
rsilver's Avatar
so thats what "hacked to death means". Very helpful info.thanks very much......bob
Old Nov 23, 2000 | 07:57 PM
gravitar's Avatar
Hopefully, that will be changing, as in an edgecard communication adapter is in the works?
Old Nov 23, 2000 | 09:16 PM
rsilver's Avatar
Gravitar, what will change and how will the edgecard communication adapter help do it?
Thanks.....bob
Old Nov 24, 2000 | 10:56 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Thanks.....bob
The edge card communications allow real time access to the CPU. You can engineer any sample rate you want. ie Direct Scan uses 19 frames a sec..
Better resolution, easier to find exactly when a Knock Signal is generated. With a slow sampling rate might be 2600-3200 rpm when it started, high sampling rate might drop it to 2975 to 3120. The difference is knowing how many places to look to cure the problem
AussiePr0nCar
Mar 6, 2020 04:04 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Keith5
Aug 27, 2015 04:37 PM
355tpipickup
Aug 19, 2015 10:02 PM
djmarch
Aug 10, 2015 08:42 AM
