corvette bins compared to f-body bins?
Old Nov 26, 2000 | 09:06 AM
blowen90ta's Avatar
anyone out there have a bin for a 1990 corvette(with auto tranny)as i would like to compare it to my 1990 ta bin and see what changes were made if any to help the corvette be top dog--i am assuming that timing values have changed to compensate for the aluminum heads
p.s i'd like to see any year bin that use speed density.
thanks
pete
1990 Trans Am,350 TPI(L98),WS6suspension ,bridgestone RE71's /245/45/zr16
paxton supercharger, alston sfc's,msd 6AL-BTM,
8.5 superconductor wires SLP 1-3/4 headers,duel cats,3"slp exaust, lakewood LCA's,T.B.Bypass
160 degree stat,alum driveshaft,fiberglass wing, secret mods
"if you cant win fair CHEAT"
Old Nov 26, 2000 | 10:00 AM
Blade's Avatar
I have quite a few bins at the "bin archive" I have on my server. There's quite a few SD bins. For F-Bodies I've noticed that from 90 to 92 they are 99% the same. It's at http://www.truspeed.org/bins.html
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
http://www.truspeed.org/Members/Chev...dmondIndre.htm
[This message has been edited by Blade (edited November 26, 2000).]
Old Nov 26, 2000 | 01:42 PM
blowen90ta's Avatar
thanks blade it's a great site and i hope to contribute to it soon as i have a slp,and a hypertech chip that i should be able to read soon.i have already downloaded a couple from your site but was told that corvettes with their aluminum heads used different spark tables and wonder if this is true?i assume so because of their better cooling capacity.
and i assume with my afr heads that the corvette bin is the one to start with in the search for perfection.
thanks
pete
Old Nov 26, 2000 | 01:58 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
thanks
pete
Universally the AUJP is the best of the SD codes to start with for an auto.
The differences will become real obvious as you start. You'll generally want more in the cruise areas and less at WOT.
As I recall the Y bod 730 even thou 8D has a few items that don't line up, and you might be starting off on the wrong foot relying too much on that. The vette heads were only 56ish chambers and that has alot to do with the burn process.
One of the big issues is being able to measure performance, and accurately figure out what the engine wants.
Rocket-Doc
Nov 14, 2015 02:08 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
the_hamturdler
Sep 30, 2015 12:50 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
