Is 3/4 throttle better than WOT (as far as ECM is concerned)
Old Nov 26, 2000 | 10:37 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
What does the ECM ignore at WOT?
O2? MAF?
If it does ignore the O2, would it make sense to max your TPS at 3/4 throttle (whatever the measurement is B4 WOT)?
This is in regards to a NO2 setup.
Mark.
Old Nov 27, 2000 | 11:49 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
O2? MAF?
Mark.
Actually at WOT it goes into a mode called Power Enrichment. It varies some by program but it is an open loop mode so the O2 information isn't used as feedback to the ecm for calculating AFRs.
All the other sensors are used, just the system is open loop.
Grumpy http://www.gnttype.org/carofthemonth...omdetails.html
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
willyjoejr
Sep 3, 2015 09:26 AM
RyanJB
Sep 2, 2015 01:27 PM
