TunerCat - TDFEditor...
Old Jan 6, 2001 | 11:08 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I was just reading up about this and wondering if anyone has any feedback about this. I thought it might be useful to create tables (like that MAT Delta table in the 8D had that is not in the 8D.tdf).
The price is cheap (only $39.95) but I wanted to see if anyone had any feedback on it first.
PS: There is a new update to TunerCat (v 1.60) for those registered users.
Old Jan 6, 2001 | 12:54 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
TNR Editor is kicka$$. I've been using it for ... ahmem ... sometime now and it is great. It allows you to add ANY parameter or table you want to the TDF file. Very cool. Before the $8D TDF file had the knock and decay tables I put them in MY TDF file and used them. Then I told TC about it and he added those tables to the standard $8D that he supplies. Its great for those who read through the HACs.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Jan 6, 2001 | 01:53 PM
Blade's Avatar
So how does one get a copy of the editor ?
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
Old Jan 8, 2001 | 09:53 AM
Car: Death Mobile
Engine: 666 c.i.
Blade, the TDFEditor is at TunerCat's web site ... same 30 day trial period as with all their software.
Thanks for the recommendation Traxion. I am still playing with my eprom's VE tables (its slow going when you only have the weekend to do tests) to get that elusive "perfect 128/128" chip for the majority of part throttle conditions. Its very close now, but I am a perfectionist.
But after that (and then the WOT), I will pickup the TDFEditor and try mucking with a table I found for the "MAT Delta" table. I found that when I went to a higher T-stat, that my mixture went richer with the either the relocated MAT or the stock MAT (but TB Bypass).
It kind of confirms that the "MAT Delta" table does compute the change to the PW based on the difference between the CTS and MAT readings as the hack code of the 8D said.
Also, FYI, using the stock MAT (but with the TB Bypass), I found that the higher T-stat DOES NOT increase the heat to the plenum. I got the same MAT reading (within a degree or 2*C) running a 160* T-stat and a 180* T-stat when I compared it to a day where the ambient air temperature was the same. The only time the stock MAT differed appreciably from each other was when I got stuck in city traffic due to sitting in traffic and the heat of the engine transferring to the plenum. But it was not extreme and on the open road...no difference at all.
So it appears this running a colder T-stat to keep the plenum from picking up heat from the engine is false for the open road and only partially true for city traffic.
ULTM8Z
Oct 2, 2015 01:25 PM
Grim Reaper
May 23, 2001 08:08 PM
Grim Reaper
Apr 20, 2001 10:40 PM
Grim Reaper
19
Jan 28, 2001 06:48 PM
