ESC module included in PROM?!!?
Old Jun 28, 2006 | 02:27 PM
Jeremy Le Dean's Avatar
Car: 1990 Iroc-z and 1989 Iroc-z Conv.
Engine: 350 TPI Vortec 472RWHP
Transmission: Tremec TKO
Axle/Gears: 7.625/3.73
Hi guys,
this is what I read on this site: 305 TPI to 350 TPI Conversion
To make it short, It says that in 730 equiped Fbodies, the ESC is phisically included in the PROM. Well, no big deal.
My proplem is: I'm swapping my 305 for a 350 with big vortech heads,big vortech style TPI manifold, big cam,juicers,intake, well big everything and I plan to use the prom switcher from Moates (I already have it though).
Does Moates equipment already take care of this or do I have to plug an existing 350 PROM on the Moates bin switcher socket?
Does anybody already encountered my problem?
Thanks guys.
Old Jun 28, 2006 | 04:48 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
You have to use the Moates G1 adapter (or similar) in a 730 to be able to plug in a DIY prom (or bin switcher or emulator for that matter). Then you plug a 350 memcal into the edge connector on the G1 so you have access to the ESC stuff. Just don't expect the limp home mode to be of much help if you have extensive mods....
Old Jun 29, 2006 | 02:00 AM
Does anyone has a schematic of this?
So I'll study it and found some way to improve it........
Old Jun 29, 2006 | 02:51 AM
Does anyone knows what differs from a 305 ESC to a 350 ESC for a given year? (let's say 1990 )
Also, does anyone knows how it works?
Damned! I know I ask a lot.
Old Jun 29, 2006 | 08:52 AM
vernw's Avatar
That one's over my head, sorry.....
Old Jun 29, 2006 | 07:23 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
If I read the question correctly, you are using a 730 but going from 305 to 350. Figuring the setup is 1990 style.
If that is the case then you will need a MEMCAL to place on your Moates adapter (which will be needed in any case) and then use the correct knock sensor for the 350.
The knock sensor is different on the 305 and the 350.
I do know the 350 sensor is 3.9K ohms, GM P/N# 10456549.
Not sure on the 305.
I don't believe there is any diff in the MEMCAL except for the "limp mode" resistors. The other ESC stuff is the same from what I understand.
Best to use a 350 MEMCAL just so your limp settings are close enough to allow you to run. Still may not run good but MAY run better than the 305 settings.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Nick McCardle
Sep 10, 2015 08:36 PM
SG91camaro
Sep 5, 2015 10:27 PM
RyanJB
Sep 2, 2015 01:27 PM
