Can anyone identify the sources of these PROMs?
Old Jan 10, 2001 | 07:01 PM
87/88Firetruck's Avatar
I have found ECMs with the following PROMS:
ACLH9778
AMJW8486
Does anyone know what these are from? Thanks.
Old Jan 11, 2001 | 10:33 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Originally posted by 87/88Firetruck:
I have found ECMs with the following PROMS: ACLH9778 AMJW8486
Yep.
ACLH 88 2.5 Auto 1227165ecm
AMJW 89 2.5 Auto 1227165
Old Jan 12, 2001 | 01:26 AM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Here are a couple of more. I hope someone can decode these numbers for me.
#1. 16035006 8605 (stamped on the side)
6E Cal
160553 8603 (Inside top hole)
#2. 68767 8724 (stamped on the side)
6E Calibration
Delco BUA 1728 (On silver colored sticker inside top hole)
Thanks for the help.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Old Jan 12, 2001 | 11:00 AM
JakeJr, the "BUA" PROM, I believe, is from a 1986 'vette. I'm not sure about the ratios, tranny, etc. I was looking all over the Houston area for an ECM/Memcal/PROM that would work with my 1987 GTA 350 TPI setup, and found this guy with a 1227165 ECM and BUA PROM from a 1986 'vette. He had some other 165s, but did not know where they came from, so I got the 'vette unit. Stupid me - everything I had read said that the VATS was not introduced until 1988, but just today there was a post stating that it began in 1986 on the 'vette. To add insult to injury, the ECM was toast. I got a lifetime warranty ECM from O'reilly's only to find that the VATS is screwing things up now that the ECM is capable enough to use it. To answer your question, though, I did call a GM dealership to confirm that the PROM was for a 1986 Corvette.
Old Jan 12, 2001 | 01:12 PM
JakeJr's Avatar
Axle/Gears: 3.07
Thanks for the info. Yes, my 86 Vette has VATS.
I'm sure someone with a burner can turn off the VATS in the PROM for you. Everything should work okay then.
I bought a rebuilt ECM from O'Reilly's too, about a year ago.
The two PROMS I posted have 89 bin files and 6E calibration (whatever that means).
They've been modified with EGR turned off, idle speed raised and a slight change to the TCC.
I suspect they are both Vette PROMS too.
Thanks again,
Jake
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
dusterbd
Sep 29, 2015 08:40 AM
