305 Based chip amazed me ! Hehe
Old Jan 11, 2001 | 11:02 AM
Blade's Avatar
After reading Kevin91Z's post about running his ZZ4 based engine with a 305 5 speed chip and getting good results I decided to give a try myself. Went to the one and only bin archive (hehe), downloaded the 91Z305T5 bin and went to work. Reset the manual/auto flag, left the injector constant at #19 and that's it. The test drive was AWESOME at part throtle. I really like it. I believe the MUCH improved part throtle response is caused by the much more agressive timing map in this bin. The VE tables look about the same. The car runs a little on the rich side (mostly 111BLMs, but 126 at idle) and it's "okay" at full throtle. I still have to play around with the tables for WOT performance but part throtle is muuucho better
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
Old Jan 11, 2001 | 12:10 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Now thats interesting, because I've run my car with both a 305 5-speed chip and a 350 automatic chip, and I dont feel any difference in the way the car acts.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 11, 2001 | 03:19 PM
Blade's Avatar
Well I sure did. And by looking at the timing tables it should. It looks much more agressive then that of a 350.
[This message has been edited by Blade (edited January 11, 2001).]
Old Jan 13, 2001 | 05:47 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
WOW I might just try that tomarrow I happen to have an gm chip for a 305 tpi 5-speed and my car is using a 350 chip with a t-5 in the car. any other mods to the chip? and what was your base timming?
Old Jan 13, 2001 | 06:05 PM
Blade's Avatar
My base timing is 6. The only thing I did was copy the WOT AFR ratio tables over from the 350 chip and the 90-100kpa VE and timing values from the 350 chip also so WOT performance stayed the same (good!). One other thing I noticed is that when I first start up the car (cold or warm) the engine doesnt rev up to like 1200-2000 then settles down to the idle RPPM after 10-15 seconds. When I start it it goes up to the idle RPM right away and stays there. I like that better.
92 Z28 L98 350
Street Lethal
Apr 30, 2019 12:14 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
bdads
Aug 24, 2015 06:01 PM
Sanjay
Aug 12, 2015 03:41 PM
