165 ecm , which eprom?
Subscribe
Jan 24, 2001 | 02:14 PM
I realize that i need the 27c128 chip
I did a little research on jdr.com and i found the 27C128A-120 chip. I just want to make sure that is the correct chip and that it will work on my car.
1987 IROC-Z L98 350 SuperRam, Edelbrock Performer 6085 Aluminum Heads, LPE RollerCam 219/219, Crane Gold Race 1.6RR, TF 1 pc Chrome Moly Pushrods, Underdrive Pulleys, Edelbrock TPI High Flow Base Manifold, Accel 58mm TB, ADS 24#, Crane AFPR, K&N, Edelbrock TES Headers, Catco Hi Flow Cat, 3" Borla Cat-Back, Accel Cap & Rotor, MSD 8.5mm, MSD 6AL Ignition, MSD Blaster 2 Ignition Coil, Hayes Clutch, 1LE Aluminum DS, 94' Z28 Disk Rear, Wilwood Adjustable Proportioning Valve, Torsen Series 3 Posi Carrier, Precision 3.73 Gears, Southside Machine Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
Reply 0
Jan 24, 2001 | 02:49 PM
Thats the one you need.
86 IROC T5
MSD 6A
Summit cam
Flowmaster
AFPR
Lowered 1.5"
My own prom (finally)
Reply 0
Jan 24, 2001 | 02:59 PM
Ok thanks , thats all i needed to know. Just gathering all of the info needed to get started on these proms!
Reply 0
Subscribe
